Wonder if anyone can assist? I got a secondhand router to play with but I cannot get the thing to reset as per detailed instructions from various sites including cisco. When booting up and pressing ctrl break, I get a cursor for a while then the thing carries on with its boot.
The part that troubles me is "Abort at Abort at 0x10A92E2 (PC)" and the text below it regarding a newer config?
Anyone any ideas or is my router knackered?
TVM
Chris
ystem Bootstrap, Version 11.0(10c), SOFTWARE Copyright (c) 1986-1996 by cisco Systems
2500 processor with 6144 Kbytes of main memoryAbort at 0x10A92E2 (PC)
%SYS-4-CONFIG_NEWER: Configurations from version 11.2 may not be correctly under stood. F3: 8032136+99456+314400 at 0x3000060
Restricted Rights Legend
Use, duplication, or disclosure by the Government is subject to restrictions as set forth in subparagraph (c) of the Commercial Computer Software - Restricted Rights clause at FAR sec. 52.227-19 and subparagraph (c) (1) (ii) of the Rights in Technical Data and Computer Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc. 170 West Tasman Drive San Jose, California 95134-1706
Cisco Internetwork Operating System Software IOS (tm) 2500 Software (C2500-J-L), Version 11.2(17)P, RELEASE SOFTWARE (fc1) Copyright (c) 1986-1999 by cisco Systems, Inc. Compiled Tue 12-Jan-99 12:50 by pwade Image text-base: 0x030401CC, data-base: 0x00001000
cisco 2500 (68030) processor (revision N) with 6144K/2048K bytes of memory. Processor board ID 11163561, with hardware revision 00000001 Bridging software. SuperLAT software copyright 1990 by Meridian Technology Corp). X.25 software, Version 2.0, NET2, BFE and GOSIP compliant. TN3270 Emulation software. Basic Rate ISDN software, Version 1.0.
1 Ethernet/IEEE 802.3 interface(s) 2 Serial network interface(s) 1 ISDN Basic Rate interface(s) 32K bytes of non-volatile configuration memory. 8192K bytes of processor board System flash (Read ONLY)Press RETURN to get started!
%LINK-3-UPDOWN: Interface BRI0, changed state to up %LINK-3-UPDOWN: Interface Ethernet0, changed state to up %LINK-3-UPDOWN: Interface Serial0, changed state to down %LINK-3-UPDOWN: Interface Serial1, changed state to down %LINEPROTO-5-UPDOWN: Line protocol on Interface BRI0, changed state to down %LINEPROTO-5-UPDOWN: Line protocol on Interface BRI0:1, changed state to down %LINEPROTO-5-UPDOWN: Line protocol on Interface BRI0:2, changed state to down %LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet0, changed state to down
%LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0, changed state to down %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial1, changed state to down %LINK-5-CHANGED: Interface BRI0, changed state to administratively down %SYS-5-CONFIG_I: Configured from memory by console %SYS-5-RESTART: System restarted -- Cisco Internetwork Operating System Software IOS (tm) 2500 Software (C2500-J-L), Version 11.2(17)P, RELEASE SOFTWARE (fc1) Copyright (c) 1986-1999 by cisco Systems, Inc. Compiled Tue 12-Jan-99 12:50 by pwade
