I have two Cisco 1602 routers that I am trying to set up as a training lab. I am very new to Cisco equipment so bear with me. I want to connect these two routers using the RJ-45 (RJ-48) serial ports that have CSU/DSU built into them.
I've connected them this way and my serial0's are up on both routers. If I unplug the cable at either router, the serial0's go down. However I cannot make these routers talk to each other and I think it is because I do not have the interfaces set up correctly. In fact I cannot even ping either routers own serial port.
I've read in numerous places about the type of cable to use. One place says a rollover cable will work, others say you need a 1,2 4,5 cable. I made one of these and it didn't work at all, serial ports would not come up. But using the rollover cable I get a carrier light on the routers and port and protocol up on the terminals.....
Anyone know of where I'm going wrong? Any help would be most appreciated....
Thanks,
