Please post a reasonable device list to obtain CCSE certification. Please DO NOT post a link to the CISCO website.
- posted
19 years ago
I assume you mean CCSP, not CCSE.
Two of these are expensive: if you're patient, you can find both the 3005 and 4210 for less than $1K on ebay. If you're thinking about going for your Security CCIE, then for the routers, I would definitely get used 3640s with
128MB of RAM and 32MB of flash.Cheers!
Richard
Thank you Sir! That is exactly what I was looking for. I did mean CCSP, and what you posted was of a great help. I do plan of trying for the CCIE Security. One last question.... why the 3640 instead of say a
3620 or the 26xx series? Thanks aga>I assume you mean CCSP, not CCSE.
The 3640 runs the latest 12.3T trains whereas the 3620 doesn't. Because of flash and RAM, I typically shy away from the 2600s if you want to run Enterprise software, which is what you'll need for the CCIE.
Cheers!
Richard
