CCNP in Germany
Threaded View
Hello alt.certification.cisco!
I'm searching a possibility to graduate the CCNP (I did CCNA in school)
in Germany. Can someone point me to some institutions where this will be
possible? Also I want to make that CCNP as cheap as possible. (CCNA is
1230 Euros I found out, here in Germany)
Hopefully you can give me some suggestions how I can graduate the next
level of certification.
Stephan Grein, <stephan at stephan minus rockt dot de>
https://stephan-rockt.de
GnuPG-Key-ID: 0xF8C275D4
FingerPrint: 5B6F 134A 189B A24D 342B 0961 8D4B 0230 F8C2 75D4
Re: CCNP in Germany
Hi Stephan,
You may wish to investigate the Cisco Global Learning Partner Locator:
http://tools.cisco.com/E-Learning-IT/LPCM/pub_jsp/lplist/LpcmLPListSearchPage.jsp
Hope this helps.
Brad Reese
Global Cisco Job Openings
http://www.bradreese.com/hot-jobs.htm#GLOBAL
Site Timeline
