Are there any LED status questions on the test?
Example: If a 2950's RPS LED is flashing amber: a. The external rps is supplying power. b. It's about to explode. c. It works, just not for you. d. None of the above.
Of course, based on what I've studied so far, the question would probably be more like:
If a 2950's RPS LID is flashing amber:
D: NONE OF THE ABOVE. IT'S LED, NOT LID YOU MORON!
Thanks,
...Joey
