Now with pictures!
Subject
- Posted on
CCNA Simulation Question
- 03-03-2007
- georgeflan
March 3, 2007, 4:39 am
I last took the CCNA in July 2001. The only thing close to a simulation
question at the time
was filling in the blank on how to add (router rip) and moving some blocks
around and matching
up fields.
What I'm wondering about the new test's simulation is what all is involved?
Is it something like a
question that says, "Setup a router with these functions"? And just gives
you a command line prompt
to start (conf t) or what?
Thanks,
Re: CCNA Simulation Question
Go to the CCNA prep center and try out their sims:
http://forums.cisco.com/eforum/servlet/PrepCenter?page=main
proxy wrote:
and yes, thats pretty much how it is. It seems the questions are that you
get a network setup with several routers that's not working and you should
fix the routing problem. That or access lists. I just passed the ccna and I
had sim about blocking telnet with an access-list, and fix an ospf routing
problem.
problem.
Site Timeline
- » Making The Pirate Bay obsolete
- — Next thread in » Cisco Certification
- » CCNA Update
- — Previous thread in » Cisco Certification
- » iPhone SUPER 80% discounts
- — Newest thread in » Cisco Certification
- » Helper Woes
- — The site's Newest Thread. Posted in » CCTV, Alarms and other Physical Security
