In tha simulators on the exam, can you use a ? or Tab keys to see what commands are available and auto fill?
Its just I use the tab key alot and I just want to know if I can it like i do at work in the exam.
Also been using the Tranzcender Pre exam stuff and I was amazed how much I don't know. Then I read that they are not that great and Boson simulators are the better way to go. Any thoughts?
Cheers
