CCNA practical question
Threaded View
Is there anyone that has a clue what the "practical" portion of the Cisco
CCNA Cert exam is like?
I'm confident I can do anything in the book if I have a reference with me.
I'm confident I can do anything reasonably basic with no reference.
What I can't get confident about is the ability to do the more complicated
or esoteric stuff without SOME kind of reference or notes available.
Ingot
Re: CCNA practical question
There is no actual "practical" portion of the CCNA cert exam in the hands-on
hardware sense, but there are questions on configuration and troubleshooting
CLI commands. There are also "simulations" where you are presented with a
topology with a scenario and a CLI type interface into which you enter the
commands.
The CCNA Prep Center has sample question types and all sorts of other good
stuff to help you.
To log in you do need to have at least a Guest Cisco.com (aka CCO)
registration but this is free and is something you should have anyway if you
are serious about this stuff
http://forums.cisco.com/eforum/servlet/PrepCenter?page=main
cheers
Aubrey
"Aubrey Adams"  wrote in message
Hmm.
Curiouser and curiouser.
Well, most of them I'm ok with, I'm just afraid of the more esoteric.
Thanks for the advice
the quetsions, trouble shooting and network design are in the lines of the
following:
1) which cable connects to what ? (you will be given devices and u have to
pick which cable is correct)
2) adding IP address and correct subnet to routers (in the simulation)
3) some IP routing issue... I dont believe there was anything that asked me
to configure any routing protocol from scratch.. most likely, wrong IP
address and or subnet...
4) some frame-relay question, IE: whats wrong with the following set of
configuration...
alot of ppl here will scare the sh1t out of you ... but dont worry .. its
extreamly easy..it took me only 45 minutes to finish the exam and I got a
96.5% while on fairly strong pain killers :p
so good luck..
I haven't taken the exam yet but I have used the test exam from boson.com,
which opened up my eyes about what to expect. I got codes to get the exams
for free with the Cisco Press ICND1 & ICND2 books by Wendell Odom, it may
work out cheaper to buy the books & get the free exam than to buy directly
from Boson, the 2 books only cost 30 in the UK (60$ US).
Double check that the boson codes are with the book before you buy if you
only want the test exams, I'm only going from the edition that I bought &
that was back in October.
Jase
Site Timeline
