So I've been seeing that there are NAT sims on the exam. As has been posted already, Sybex CCNA 5th ed has almost nothing on NAT, and what is there is basically a summary. So how in-depth are the NAT sims? Do you have to be able to set up dhcp pools and do overloading, or is knowing how to set up a static fine? I'm fine w/ the latter, but will have to spend a bit more time on it if have to go the whole ball of wax. Only have about 5 days to go before testing, and would like to concentrate on FR relay more.
bk
