Scott Mackenzie, AT&T engineer with CCNA, CCNP, CCDA, CCDP, CQS Wireless FE, and CQS Wireless SE certifications had this to say:
On it's face, the CCDA/DP would be a good focus for pre-sales / Design Engineers / possibly project managers.
Secondary to that, it's also a Very Good Thing(IMO) for the troubleshooting side of the house.
Assuming that you will ultimately be working on / troubleshooting a system that was designed and built "in the Cisco way," it helpful to have an understanding on WHY something was architected the way it was.
While it is, to some degree, true that "a switch is a switch, a router is a router" it's also very true that a systems architect (if they're worth a damn) will take advantage of the features offered beyond the basic functionality of the device and design the system as a whole ... .not one chunk at a time / one device at a time.
Having the knowledge and skillset of the CCDA/DP gives you (at the least) the basic concepts that drive the design of the system and help you figure out where it's broke (according to what it was designed and built to do).
CCDA is not so much of a "slam dunk" .... as a test, you are given a few paragraphs of background and asked questions related to how you would approach the issues presented ... you have to give it due ponderance and "think like Cisco" to properly resolve the challenge.
Given that there are a zillion ways and philosophies to implement a system for any given situation, much of the "trick" to passing the CCDA/DP is to think in terms of doing it the "Cisco Way."
Hope this helps.
Brad Reese on Cisco Network World Magazine Cisco Subnet
