I have a CAT 5509 running and it seems to be a little slow, I have ran a troughput test with two PC connected to the same VLAN via a hub and it seems pretty slow, could some one look at this for me and see if there is anything that stands out that is causing me issues: -
Cisco Internetwork Operating System Software IOS (tm) C5RSM Software (C5RSM-ISV-M), Version 12.0(10), RELEASE SOFTWARE (fc1) Copyright (c) 1986-2000 by cisco Systems, Inc. Compiled Wed 22-Mar-00 04:15 by phanguye Image text-base: 0x60010930, data-base: 0x60ADE000
ROM: System Bootstrap, Version 11.2(17523) [mohsen 102], INTERIM SOFTWARE BOOTFLASH: C5RSM Software (C5RSM-BOOT-M), Version 11.2(12a.P1)P1, MAINTENANCE IN TERIM SOFTWARE
System image file is "slot0:c5rsm-isv-mz_120-10.bin"
cisco RSP2 (R4700) processor with 65536K/2072K bytes of memory. R4700 processor, Implementation 33, Revision 1.0 Last reset from power-on G.703/E1 software, Version 1.0. G.703/JT2 software, Version 1.0. X.25 software, Version 3.0.0. Bridging software.
1 C5IP controller (4 Vlan). 4 Virtual Ethernet/IEEE 802.3 interface(s) 123K bytes of non-volatile configuration memory. 16384K bytes of Flash PCMCIA card at slot 0 (Sector size 128K). 8192K bytes of Flash internal SIMM (Sector size 256K). Configuration register is 0x2102version 12.0 service timestamps debug uptime service timestamps log datetime service password-encryption ! hostname cat-5509 ! boot system flash slot0:c5rsm-isv-mz_120-10.bin no logging console enable password removed ! ip subnet-zero ip cef no ip domain-lookup ! ! ! interface Loopback0 ip address removed no ip directed-broadcast interface Loopback5 ip address removed no ip directed-broadcast ! interface Null0 no ip unreachables ! interface Virtual-TokenRing900 no ip address no ip directed-broadcast ring-speed 16 ! interface Vlan23 description ip address removed no ip directed-broadcast ip route-cache flow no ip route-cache cef ! interface Vlan44 ip address removed no ip directed-broadcast no ip route-cache cef ! interface Vlan901 ip address removed no ip directed-broadcast no ip route-cache cef
Many thanks
Chet
