I am trying to set up a 1720 with 2 BRI cards in to connect to another
1720 with 2 BRI cards in. The problem I have is that I cannot get the Dialer profile to use BRI0 it always tries to use BRI1 even when there is no line connected. The config from the router initiating the call is shown below:Current configuration : 1460 bytes ! version 12.2 service timestamps debug uptime service timestamps log uptime service password-encryption ! hostname Remote1 ! enable password xxxxxxxxxxxxxxxxxxxx ! username ACMan password 0 xxxxxxxxxx memory-size iomem 25 ip subnet-zero no ip domain-lookup ip dhcp excluded-address 172.15.1.1 172.15.1.9 ! ip dhcp pool lanpool network 172.15.1.0 255.255.255.0 dns-server 172.16.1.7 172.16.1.19 default-router 172.15.1.2 ! isdn switch-type basic-net3 ! interface BRI0 no ip address encapsulation ppp dialer pool-member 1 no shutdown ! interface BRI1 no ip address encapsulation ppp dialer pool-member 1 no shutdown ! interface FastEthernet0 ip address 172.15.1.2 255.255.255.0 speed auto full-duplex no shutdown ! interface Dialer1 ip unnumbered FastEthernet0 encapsulation ppp dialer pool 1 dialer remote-name ACMan dialer string xxxxxxxxxxxxxxxxxxx dialer load-threshold 1 outbound dialer-group 10 ppp authentication chap ppp multilink ! ip classless ip route 0.0.0.0 0.0.0.0 Dialer1 no ip http server ! access-list 100 deny udp any any eq netbios-ns access-list 100 deny udp any any eq netbios-dgm access-list 100 deny tcp any any eq 139 access-list 100 permit ip any any dialer-list 10 protocol ip list 100 ! line con 0 password xxxxxxxxx line aux 0 line vty 0 4 password xxxxxxxxx login ! no scheduler allocate end
later
Ben
