Folks - if anyone is using this netsim, I could use your input. I simply cannot seem to get the sequential Lab 19 to work as per the lab guide. I believe it is a bug in the software but can't get a response from Boson.
Has anyone managed to get the pings to work between router1 and router2 using the ISDN PRI on router2? It seems the 'encapsulation ppp' command doesn't stick to the serial0/0:23 interface as required by the lab guide.
