I need AUI DB15 to Rj45 cable. Can anybody help me with pinout, please?
thanks!
thanks!
If you are looking for something to convert an AUI ethernet signal to
10Base-T ethernet then you need a transceiver that accepts the AUI signal and retransmits it as 10Base-T ethernet.It's more complicated than just a Mod-Tap adapter. Different kinds of signal and different formats. Both ethernet, yes, but different formats.
See if this is what you are looking for... Not too expensive either...
John
MM...are you wanting to go from 10b2 Ethernet to 10BT Ethernet?.... If so, you dont need a "gender bender cable". what you need is an actual transciever. You can usually pick them up for about 10 bucks a pop off of Ebay...an ALLLIED TELESIS 210TS is a very popular one but there are many different brands. All do the same thing.
Good luck
DD
Yes.I thought that i can make alone converting cable. Thank you!
Nope... as stated above. You'll need a transceiver..
