another wrong answer?
This is from the 1.7 INTRO question bank update downloaded from ciscopress.com:
Interface B is set up to use the RIP routing protocol: RouterB(config)#router rip enable
RouterA#config terminal
RouterA(config)#interface Serial0/0
RouterA(config-if)#ip address 10.1.1.1 255.255.255.0
RouterA(config-if)#clock rate 64000
RouterA(config-if)#no shut
RouterA(config-if)#interface FastEthernet0/0
RouterA(config-if)#ip address 172.16.1.1 255.255.255.0
RouterA(config-if)#no shutdown
RouterA(config-if)#exit
RouterA(config)#router ospf 1
RouterA(config-router)#network 10.1.1.1 0.0.0.0 area 0
RouterA(config-router)#network 172.16.1.1 0.0.0.0 area 0
RouterB>enable
RouterB#config terminal
RouterB(config)#interface Serial0/0
RouterB(config-if)#ip address 10.1.1.2 255.255.255.0
RouterB(config-if)#no shut
RouterB(config-if)#interface FastEthernet0/0
RouterB(config-if)#ip address 192.168.1.1 255.255.255.0
RouterB(config-if)#no shutdown
RouterB(config-if)#exit
Mark Scott
You're correct: the "router rip" command on Router B is obiviously wrong. Are you sure you downloaded the INTRO update? This sounds like a question from the ICND test bank.
Allan Wingenbach
Allan Wingenbach
Yeah, it was the update, the questions now load up "boson" and are not shown until you actually click the sim button
Mark Scott
