ACL matches in 6509
Threaded View
Need help in this... I can't see the hits (matches) against each ACL
when I use "show ip access-list" in 6509, like I can see in 7513 and in
other routers. Is there any way to see those matches, since it's being
denied or processed by dcef, except disabling the fast switching? I am
using Native.
And how can I get into MSFC2 in native mode?
Re: ACL matches in 6509
You dont need to in native mode- the config is for both sup and msfc. ie
you see the layer 2 ports and layer 3 vlan int on the same config
in cat/hybrid use session command or just telnet
Site Timeline
