Which of the following actions can you to prevent newly configured commands from being sent to a target router? A. delete B. remove C. undo D. clear-commands E. refresh
This is a question from TestKing but without a answer.
E, Refresh. It is refering to using ADSM for your configuration. The configuration is done in the java aplet and is then pushed to the router once you approve it. The refresh clears those temporary commands that are in the applet prior to your pushing them to the router.
