Cisco Certification Issue with Cisco Pix 501, and MS VPN connecting to Cisco 3005 VPN? Multiple connections
Subject Author Date
Issue with Cisco Pix 501, and MS VPN connecting to Cisco 3005 VPN? Multiple connections rhalljr 02-11-08
Posted by rhalljr on February 11, 2008, 10:03 am
We are setting up a temporary satellite office about 15 minutes away,
and we are running into a minor problem with the client connectivity
from that office.
Ill explain the hardware real quick. In our main office, we have a PIX
506e Firewall, with the 3005 Concentrator behind it for VPN. We are
using the MS client via PPTP to connect for VPN.
In the satellite office, we simply have a Pix 501, with 6-8 client
desktops behind it. We will need all of them to be able to connect to
the Cisco VPN using the MS Windows VPN connection.
Is there something i need to do to make this happen? Right now it
appears that one 1 of them at a time can connect.
Thanks in advance.... I am not a cisco certified guy yet, but i plan on
working towards it someday soon.
Rodney
Posted by Yandy Ramirez on February 11, 2008, 10:26 am
Yes for windows PPTP clients you need to inspect PPTP at the PIX level.
We ran into an issue like that.
Versions <= 6.3
Fixup protocol pptp 1723
Also allow GRE on your access lists.
Version >= 7.0
pixfirewall(config)#policy-map global_policy
pixfirewall(config-pmap)#class inspection_default
pixfirewall(config-pmap-c)#inspect pptp
Hope that helps.
You may also need to allow GRE through.
On 2/11/08 10:03 AM, in article 47b063be$0$8649$4c368faf@roadrunner.com,
> from that office.
> Rodney
Posted by rhalljr on February 11, 2008, 10:48 am
> Versions <= 6.3
> Version >= 7.0
> Hope that helps.
>> from that office.
>> Rodney
thanks, will be going down there and trying it today!!
I will let you know
Posted by rodney on February 12, 2008, 1:54 pm
Sorry, i should have informed you that we are at version 6.3(5) for the
pix 501.
I already these entries in place.
Is there something else i should be looking for?
> Versions <= 6.3
> Version >= 7.0
> Hope that helps.
>> from that office.
>> Rodney
Similar ThreadsPosted
Issue with Cisco Pix 501, and MS VPN connecting to Cisco 3005 VPN? Multiple connections February 11, 2008, 10:03 am
Multiple immediate openings! Cisco engineers!! January 19, 2006, 1:12 pm
Cisco DHCP Multiple Subnets September 1, 2008, 4:29 pm
Cisco Avaya dot1q trunk issue March 22, 2006, 6:00 am
Wierd issue with Cisco 871w router January 19, 2007, 9:33 pm
Connecting to a Cisco router's Console port via Zterm - Issues August 1, 2007, 1:31 am
problem in connecting lansey ADSL modem with cisco catalyst 2950 switch. July 13, 2006, 8:21 am
3005 Concentrator L2L quesitons? May 9, 2006, 1:00 am
Bridge two DSL Connections? March 3, 2005, 8:19 pm
Odd question about serial connections December 26, 2005, 7:58 pm
Multiple public IP behind PIX 501 December 1, 2005, 7:43 am
Multiple public IP behind PIX 501 December 1, 2005, 7:44 am
switch port on multiple vlans March 21, 2005, 6:21 pm
Multiple OSPF Stub Areas March 17, 2006, 5:56 pm
multiple ethernet router choice September 11, 2006, 10:36 am
