Cisco Certification DSL router that sapports static and dynamic ip addressing
Subject Author Date
DSL router that sapports static and dynamic ip addressing Alan S 04-24-06
Posted by Alan S on April 24, 2006, 1:12 pm
We are looking at buy a DSL router that will dynamically assign IP
address to the client PC but also allows a static IP address for the
server. We are looking at Linksys BEFSX41 and Linksys Rt41-BU routers.
Does anyone know if ether of these router will have the fetchers I need?
Thanks
Posted by on April 24, 2006, 10:21 pm
Pretty much all consumer switch/router boxes have a DHCP server that
will allow you to assign a static IP for a particular internal host.
You just need the MAC address of that host, and the IP you want to
always assign to it.
Steve Griffin
www.blueconsole.com (Bluetooth Wireless Console Cable)
Posted by q_q_anonymous@yahoo.co.uk on April 25, 2006, 11:48 am
> Thanks
by 'home router' I mean the linksys thing like you refer to. one of
those routers with dhcp server and nat. I don't mean 'router at home'.
I mean, those cheap routers that people tend to have at home.
(note- i don't know anything else ;-) )
The IP address of the server will be as fixed as the IP addresses of
all the PCs. Anything plugged into that 'home router' on that side of
the router, has fixed IP addresses.
The router's IP will be dynamically assigned by the ISP and may not be
static.(Make sure your ISP gives you a static one)
Anybody outside will connect to the router through the router's IP.
The IPs assigned by your 'home router' to connected computers are only
used internally. Externally, those comps aren't even addressed.
If you have an ISP that gives you a static IP, then your 'home router'
can use that one. And you set up port forwarding so your server , so
effectively, it's as if your server has a static ip.
Similar ThreadsPosted
DSL router that sapports static and dynamic ip addressing April 24, 2006, 1:12 pm
Dynamic NAT May 31, 2005, 2:33 pm
dynamic? March 3, 2006, 2:08 am
dynamic VPN tunnel April 29, 2005, 7:54 am
Dynamic Outside Translation October 17, 2005, 8:27 pm
Re: Dynamic Outside Translation October 17, 2005, 8:28 pm
IP Addressing Questions? February 19, 2005, 9:59 pm
Benefits of hierarchical addressing May 7, 2005, 7:11 pm
Classful and classless addressing March 24, 2006, 5:19 pm
CCNA IP Addressing Resources May 23, 2007, 1:32 am
How to configure static arp on a switchport October 14, 2005, 6:18 am
DHCP + static IP on the same network? May 18, 2008, 2:26 am
CCIE Static Labhardware recommendation February 24, 2005, 12:00 pm
Individual static NAT on subnet 8, question? May 31, 2005, 4:00 am
static default route, different metric problem December 12, 2006, 9:06 am
