Cisco Certification Can't connect XP workstation to Cisco network
Subject Author Date
Can't connect XP workstation to Cisco network GC 03-27-06
Posted by GC on March 27, 2006, 8:03 am
I'm a Cisco novice with a small lab setup in my basement. (1) 2501, (1)
2514, (1) 2507 running variations of 11.1 and 11.2, a few hubs and a Linksys
WAP.. I have them routing between themselves and have, at one time or
another, successfully used all of the serial and ethernet ports on all of
the routers. So I am confident that everything is functional. Obviously,
all private addressing.
So, here is my problem. I have a workstation running XP Home and cannot for
the life of me get the workstation to talk to any of the routers. Ethernet
comes on the workstation and routers. But the routers see 100% FCS errors
on the interface.
I have direct connected them to the Ex ports on the 2501 and 2514 and have
connected via an external hub. I have connected them to the hub ports on
the 2507. I have used straight cables and cross over cables. On 11.2 and
11.2 I can't (or don't know how to) set polity but the 2507 has an
auto-polarity setting. No luck.
As I have been able to use all the interfaces cleanly by connecting various
routers to them I think it is in my XPHome setup. I am basically setting up
the fixed IP address assocaited with the ethernet subnet I am connecting to.
This seemed so basic to me. I'm sure it is something simple...but I'm
stumped.
Posted by M&MCon on March 27, 2006, 8:34 am
Make sure that you are on the same subnet. Get a rollover cable and
connect to the routers via hyperterminal. You are able to see the
configuration of the routers using a rollover. You would use a
crossover to connect a PC to a router.
Posted by Merv on March 27, 2006, 8:48 am
FCS errors usually indicates a bad NIC.
Do you know that the NIC in the Windows PC is functional?
Try setting the NIC to 10-half instead of auto
Posted by Joey on March 27, 2006, 8:56 am
Also check that infernal XP Firewall (pun intended). Turn it off and check.
Posted by GC on March 29, 2006, 1:01 am
Yes, the NIC works if I plug it into my Linksys. I did try playing with the
duplex settings in the Netowrk config. In 11.2 and prior you can't set (or
I don't know how) duplex on the routers. So thought this might be in. To
no avail.
I'm doing something wrong here.
Similar ThreadsPosted
Can't connect XP workstation to Cisco network March 27, 2006, 8:03 am
We can only connect to 1 cisco VPN from inside our network?? March 22, 2007, 2:01 pm
rsh error trying to connect to cisco 1601 router June 5, 2006, 10:20 am
Respected Cisco trainer Wendell Odom blogging for Network World's Cisco Subnet September 10, 2007, 5:48 pm
Cisco vs. BradReese.Com: Is Cisco winning the certified network engineer talent portal race? August 4, 2008, 10:15 pm
Cisco network Assistant May 30, 2005, 10:45 pm
Cisco Network Assistant 4 April 27, 2006, 3:39 pm
Senior Cisco Network Engineer September 29, 2006, 11:41 am
Network Engineer/Network Administrator/Information Technology Job Openings in USA March 3, 2008, 4:11 pm
Study-guides for Cisco Network Certification December 19, 2005, 7:01 am
End-to-End Network Security: Defense-in-Depth by Cisco Pre ss October 4, 2007, 10:42 pm
This week in Network World's Cisco Subnet February 20, 2008, 1:34 pm
Cisco 3750 initialization drops network connectivity May 19, 2005, 1:46 am
Network & Peripherals, Cisco Routers and Switches Source ! June 28, 2006, 11:29 am
comScore Seeking a Cisco Certified Network Manager July 25, 2007, 3:21 pm
