Cisco Certification CISCO 801
Subject Author Date
CISCO 801 John Biggs 12-28-05
| `--> Re: CISCO 801 John Biggs12-28-05
Posted by John Biggs on December 28, 2005, 5:57 pm
At home, I currently use a D-Link DU-128TA+ to connect a single PC to the
WWW via a 64k ISDN (yes we live out in the wilds, miles from an ADSL served
area).
My kids want their PCs to share ISDN link provided by my office. So I
bought a CISCO 801 ISDN router over eBay for £30 and set out to share the
link. The 801 came with power supply and orange ISDN cable and Ethernet
Cable plus a blue 'console' cable, but no CD.
Will I be able to use this kit by downloading any software from the WWW?
I presumed that I would be able to browse the Router over a TCP/IP
connection (with more modern equipment, I have found it relatively easy to
set up routers with Cable or ADSL modems).
I can't find out how to get into any Cisco settings pages.
If you can give me any advice I would be very grateful.
Happy New Year,
Jon
Posted by ju on December 28, 2005, 6:04 pm
Hi Jon,
Congratulations on your Cisco purchase. However, unfortunately although
the 801 can support a HTTP management gui.
It's of no use unless you have knowledge of the basic configuration
requireents of a Cisco router.
It is nothing like your D-Lin or another router of that ilk. If that was
your requirement
you should have probably looked at the 837 or similar range.
I'm certain, that any or many people on the forum would write a base config
for you.
Again, However...! are the kids going to dial your work isdn..? will your
work mind..?
dialling this number may place them directly on your works LAN. Will they
dial up to a pay
as you go number (ADSL is alot cheaper)..?
You would still need to provide a large amount of info (That would be a big
security risk to u..)
to enable anyone doing this for you.
My advice, accept that you've paid money for a box you probably cant make
any use for
accept for placing it back on ebay. review your existing and potential
connections work or personal..
Regards
Ju
> Hi,
> served area).
> to set up routers with Cable or ADSL modems).
> Happy New Year,
> Jon
Posted by John Biggs on December 28, 2005, 6:32 pm
Thanks for the reply. I will see if anyone else comes up with another offer
of help. If not it looks like I've purchased a lemon. Well thats life, you
live and learn.
Jon
> Hi Jon,
> your requirement
> config for you.
> work mind..?
> dial up to a pay
> big security risk to u..)
> any use for
> Regards
> Ju
>> Hi,
>> the WWW via a 64k ISDN (yes we live out in the wilds, miles from an ADSL
>> served area).
>> Happy New Year,
>> Jon
Posted by Dom Wilko on January 4, 2006, 8:25 pm
Hi Jon,
I saw your post and thought I would offer my assistance to help you get your
Cisco 801 working.
Unfortunately it doesn't have a GUI interface which you can use via your
browser, but I can explain how to connect to it and can probably get you up
and running with a sample configuration.
Give me a shout back if you still want assistance.
Cheers,
Dom Wilkinson
Cisco CCNA, CCDA, CCNP
ps As the 801 only has one Ethernet interface, you're going to need a small
Ethernet hub or switch if you want to share the ISDN with 2 computers.
> Hi,
served
> area).
to
> Happy New Year,
> Jon
Similar ThreadsPosted
Respected Cisco trainer Wendell Odom blogging for Network World's Cisco Subnet September 10, 2007, 5:48 pm
Cisco vs. BradReese.Com: Is Cisco winning the certified network engineer talent portal race? August 4, 2008, 10:15 pm
US - NY, NJ, AZ, PA, FLA - All Levels Cisco Pros Needed - We are Cisco placement specialists August 16, 2006, 10:37 am
CISCO - CISCO Secure Firewalls! An important Worth to Read May 17, 2007, 10:11 am
Issue with Cisco Pix 501, and MS VPN connecting to Cisco 3005 VPN? Multiple connections February 11, 2008, 10:03 am
Newly minted Cisco CCNA seeks helpful suggestions on gaining entry-level Cisco experience August 14, 2007, 3:42 am
Re: Cisco Rack Rental and Lab Scenarios for Cisco Certificat October 20, 2006, 10:25 am
Cisco pix 515 + static routes between 2 cisco pix October 13, 2005, 8:11 pm
Cisco Lab & Free Cisco Software February 10, 2006, 7:57 pm
back-to-back cisco to non-cisco cables March 6, 2005, 11:45 pm
Cisco PIX June 2, 2005, 6:07 am
cisco 837 August 19, 2005, 8:40 pm
Cisco 501 November 22, 2005, 9:31 pm
Cisco job UK December 4, 2005, 6:26 pm
CISCO 801 December 28, 2005, 5:57 pm
