So I passed the 642-831 on my second try. Two questions:
1) Are the BCRAN and BSCI easier or tougher than the troubleshooting exam?2) There was the same damn simulation on both exams: A router has three interfaces, two of which are "ip nat inside," and one of which is "ip nat outside". Currently, ip nats appear to be translating one inside local to an inside global. Nothing is working, and the nat looks roughly:
int loopback1 ip address 192.168.1.0 255.255.255.0
int f0/0 description internal ip address 10.0.0.1 255.255.255.0 ip nat inside
int f0/1 description dmz ip address 10.10.0.1 255.255.0.0 ip nat inside
int serial 1 int 172.1.1.1 255.255.255.252 ip nat outside
ip nat inside source static 10.10.10.10 192.168.1.32 ip nat inside source list 1 interface loopback1 overload
access-list 1 permit ip 10.0.0.0 0.255.255.255
All interfaces are up, no debug is allowed, "show ip nat statistics, and show ip nat translations are ok"
Show ip nat translations shows the one static translation, yet nobody can cross the serial link nor access the web server. Is this configuration just completely illegal or is there something that should be obvious to me?
Thanks, Owen
