Hi
Am trying to power a class 3 device off a 48 port 3560 PoE version (obviously!) It's a door entry system and is compliant with 802.3af.
According to Cisco literature, the switch has intelligent power management which will automatically deliver the required power to each port as required. This is within the total power budget of 370W so you could not power more than 24 class 3 devices at 15W per device.
However, I cannot get this class 3 device to work on the 48 port switch although it will work on the 24 port version and it does work on HP switches as well.
Has anyone come across this problem and do you know of any solutions?
Thanks.
