3750 routing help
I have a Cisco 3750 Fiber switch, 4 4948, and 1 2960g switches. The problem I'm having is I can only get the 3750 switch to ping the gateway the rest of the switches will not ping the gateway. I have ip routing enabled, multiple vlan's created. Each switch can ping each other, and there vlan's, but just will not ping the gateway. I'm pretty new to cisco equipment so any advise will be helpful. If you need to see my config let me know.
Mr.Minor
my first instinct is to have you give us more information..
  1. trunk ports enabled?
  2. all vlan 1 interfaces on the same subnet?
  3. ip default-gateway command used?
post the relevant portions of the configs:
include the interface configs for switch to switch connections as well.
john smith
This is my config on the core switch. Unfortunately I have to wait to give you the remaining configs on the other switches. I'm limited with the amount of down time I can have, but I will post those asap.
Thanks for you help!
version 12.2 no service pad service timestamps debug uptime service timestamps log datetime no service password-encryption service sequence-numbers ! hostname VEC_MAIN ! enable secret 5 $1$KzQ7$iv27874dMGaToEjNhlqw.0 enable password *********** ! no aaa new-model switch 1 provision ws-c3750g-12s vtp interface 10.147.30.1 ip subnet-zero ip routing ! ! mls qos map cos-dscp 0 8 16 26 32 46 46 56 ! ! no file verify auto spanning-tree mode pvst spanning-tree extend system-id ! vlan internal allocation policy ascending ! interface GigabitEthernet1/0/1 switchport trunk encapsulation dot1q switchport mode trunk ! interface GigabitEthernet1/0/2 switchport trunk encapsulation dot1q switchport mode trunk macro description cisco-switch auto qos voip trust spanning-tree link-type point-to-point ! interface GigabitEthernet1/0/3 ! interface GigabitEthernet1/0/4 ! interface GigabitEthernet1/0/5 ! interface GigabitEthernet1/0/6 ! interface GigabitEthernet1/0/7 ! interface GigabitEthernet1/0/8 ! interface GigabitEthernet1/0/9 description IT2 switchport trunk encapsulation dot1q switchport mode trunk macro description cisco-switch auto qos voip trust spanning-tree link-type point-to-point ! interface GigabitEthernet1/0/10 description IT1 switchport trunk encapsulation dot1q switchport mode trunk macro description cisco-switch auto qos voip trust spanning-tree link-type point-to-point ! interface GigabitEthernet1/0/11 switchport trunk encapsulation dot1q switchport mode trunk macro description cisco-switch auto qos voip trust spanning-tree link-type point-to-point ! interface GigabitEthernet1/0/12 ! interface Vlan1 ip address 10.147.30.1 255.255.255.0 ! interface Vlan3 ip address 10.147.24.1 255.255.255.0 ! interface Vlan4 ip address 10.147.31.1 255.255.255.0 ! interface Vlan5 ip address 10.147.9.2 255.255.255.0 ! interface Vlan10 ip address 10.147.8.2 255.255.255.0 ! router rip network 10.0.0.0 ! ip default-gateway 10.147.30.1 ip classless ip default-network 10.0.0.0 ip route 0.0.0.0 0.0.0.0 10.147.8.1 ip http server ! ! control-plane ! ! line con 0 line vty 0 4 password ******** no login line vty 5 15 password ******** no login
john smith wrote:
Mr.Minor
