I'm new to the 3005 so forgive me if I have a stupid question. I can setup a lan 2 lan IPsec with no problem but I can't figure out how to route another SA or subnet across that same IKE policy/tunnel. When I tried to add another L2L it says that you can only use the peer once. On a pix you just add an access list for for each data pattern that you want to go across the tunnel.
Any help would be appreciated.
Thanks
