I am trying to configure a 2600 router. I made a rollover cable and get the router to boot, but when I try to send key commands or text, I don't seem to be getting any response from the router. I tried ctrl-break to cycle the router and do a password recovery, but it stills boots from image. After booting it goes to the router command, but without the #. as in rt when I type enable it was not echoing the text, so I changed that in the ansi properties and it shows what I am typing. I tried switching to the aux port and I get no output there.
The settings on my hyperterminal connection are: terminal keys emulation: autodetect telnet terminal ID: ANSI ascii setup: the only one there checked is to wrap lines that exceed terminal width
Any Ideas would be greatly appreciated
