I have 1 Cisco 1601 R and 1 Cisco 1601, both serial interface are connect with a DB-60 DTE/DCE cable.
THE SERIAL INTERFACE ON DCE GOES DOWN AFTER IT COMES UP. I GET "UP - DOWN"
THE SERIAL INTERFACE ON DTE GOES UP DOWN UP DOWN UP DOWN. I GET "UP - DOWN".
I CANT GET IT UP AND UP ON BOTH ROUTES. WHAT I'M I DOING WRONG. HELP!
------------------------------------------------------------------------------------------------------------------------------ This is router 1 with the DCE cable.
------------------------------------------------------------------------------------------------------------------------------ Serial0 is up, line protocol is down Hardware is QUICC Serial Internet address is 10.0.0.1/8 MTU 1500 bytes, BW 1544 Kbit, DLY 20000 usec, rely 255/255, load
1/255 Encapsulation HDLC, loopback not set, keepalive set (10 sec) Last input never, output 00:00:04, output hang never Last clearing of "show interface" counters never Input queue: 0/75/0 (size/max/drops); Total output drops: 0 Queueing strategy: weighted fair Output queue: 0/64/0 (size/threshold/drops) Conversations 0/4 (active/max active) Reserved Conversations 0/0 (allocated/max allocated) 5 minute input rate 0 bits/sec, 0 packets/sec 5 minute output rate 0 bits/sec, 0 packets/sec 0 packets input, 0 bytes, 0 no buffer Received 0 broadcasts, 0 runts, 0 giants 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort 343 packets output, 21246 bytes, 0 underruns 0 output errors, 0 collisions, 121 interface resets 0 output buffer failures, 0 output buffers swapped out 165 carrier transitions DCD=up DSR=up DTR=up RTS=up CTS=upInterface IP-Address OK? Method Status Protocol Ethernet0 172.1.1.121 YES NVRAM up up Loopback0 192.168.1.1 YES NVRAM up up Serial0 10.0.0.1 YES manual up down
------------------------------------------------------------------------------------------------------------------------------ ROUTER 2 WITH DTE CABLE.
------------------------------------------------------------------------------------------------------------------------------ Serial0 is up, line protocol is down Hardware is QUICC Serial Internet address is 10.0.0.2/8 MTU 1500 bytes, BW 1544 Kbit, DLY 20000 usec, rely 255/255, load
1/255 Encapsulation HDLC, loopback not set, keepalive set (10 sec) Last input 00:00:00, output 00:00:00, output hang never Last clearing of "show interface" counters never Input queue: 0/75/0 (size/max/drops); Total output drops: 0 Queueing strategy: weighted fair Output queue: 0/64/0 (size/threshold/drops) Conversations 0/1 (active/max active) Reserved Conversations 0/0 (allocated/max allocated) 5 minute input rate 0 bits/sec, 0 packets/sec 5 minute output rate 0 bits/sec, 1 packets/sec 191 packets input, 16282 bytes, 0 no buffer Received 71 broadcasts, 0 runts, 0 giants, 0 throttles 2 input errors, 0 CRC, 1 frame, 0 overrun, 0 ignored, 0 abort 548 packets output, 31130 bytes, 0 underruns 0 output errors, 0 collisions, 90 interface resets 0 output buffer failures, 0 output buffers swapped out 237 carrier transitions DCD=up DSR=up DTR=up RTS=up CTS=upInterface IP-Address OK? Method Status Protocol Ethernet0 172.1.1.131 YES NVRAM administratively down down Loopback0 192.168.1.151 YES NVRAM up up Serial0 10.0.0.2 YES NVRAM up down
