Hi all
I am getting myself into Cisco VPN stuff, I have the Cisco windows client, which as far as I can make out is pretty easy to configure, the router config though is proving to be a bit more of a struggle, below is the config as best I could gather from Cisco's site, can anyone see where I'm going wrong? it doesn't seem to be blatantly obvious, not to me anyway..!!
Thanks in advance.
For obvious reasons some of the config has been omitted
aaa new-model
! !aaa authentication login cisco local
aaa authorization network cisco local
aaa session-id common
enable secret 5 $1$/0E2$Q667leuW8jel3wn8NJ8GS/
!username cisco password 0 cisco123
! !crypto isakmp policy 3
authentication pre-share
group 2
!crypto isakmp client configuration group vpnclient
key cisco123
dns 192.168.0.4
wins 192.168.0.4
domain dens.home.com
pool ippool
! !crypto ipsec transform-set myset esp-des esp-md5-hmac
! !crypto dynamic-map dynmap 10
set transform-set myset
reverse-route
! !crypto map clientmap client authentication list dennis
crypto map clientmap isakmp authorization list dennis
crypto map clientmap client configuration address respond
crypto map clientmap 10 ipsec-isakmp dynamic dynmap
! ! ! !interface Loopback0
ip address 192.168.2.1 255.255.255.0
ip nat inside
!interface BRI0
no ip address
shutdown
!interface FastEthernet0
ip address 192.168.0.20 255.255.255.0
ip nat inside
speed 10
half-duplex
!interface Serial0
bandwidth 10000000
ip address 172.16.1.2 255.255.255.252
ip nat outside
ip policy route-map vpn-client
no fair-queue
clockrate 8000000
!router rip
version 2
network 172.16.0.0
network 192.168.0.0
no auto-summary
!ip local pool ippool 10.1.1.1 10.1.1.2
ip nat inside source list 101 interface Serial0 overload
! !access-list 101 permit ip any any
access-list 144 permit ip 10.1.1.0 0.0.0.255 any
!route-map vpn-client permit 10
match ip address 144
set interface Loopback0
