Can anyone tell me why I loose my configuration settings everytime the router reboots or I power it off? Should I use the "Boot Sys" command to tell it where my config is?
- posted
18 years ago
also check the config register.
Doan
are you writing the configuration to startup?
Also check for additional "boot " commands in the running config
