Wiring home for satellite & ethernet
Threaded View
I have a 3 bedroom home which I want to run ethernet and coax
througout. The only problem is that there is no attic/crawl space and
it's on a slab. The home has tile throughout (new - put in by previous
owner) so I prefer not to take it up.
I would like to run one of those all-in-one cables (2 each of coax,
fiber and cat5) however, I have no idea on how to do this. My initial
plan was to drill holes in the wall and somehow drill through each beam
but that would require holes in the wall ever 18 inches =). Another
possibility is to somehow get the wires to the ceiling and hope I can
(from inside the house) get the wires to the garage where the wire box
will be.
Is anyone experienced in an install like this and have some
suggestions? Would a good electrician be able to handle this with ease?
I wouldn't mind paying some $$$ if they could do it without running the
wires outside or whatnot.
Any tips/pointers would be greatly appreciated.
Jim
Re: Wiring home for satellite & ethernet
No attic?  That's where LV is usually run.
If you don't want to go outside, you'll have to go inside.
Surface runs like in Europe.
You could also go into the drywall, but you will make a mess.
Studfinder for the direction of ceiling beams/furring strips.
This will be a messy PITA.  Wireless may be better.
-- Robert
The best advice is to look for a cabling contractor.  Most
electricians, while qualified by the local authority having
jurisdiction for permits and fire safety, have no real clue about
installing data cabling.  It is a specialized subset of electrical
work.  Kind of like going to a eye doctor for a foot problem.  Both are
doctors, but the work they do is very different.
beam
ease?
the
The neighbors had an exterior grade plastic square tube installed for
the CATV, and it's been up for about a year.  It's like panduit, I
believe it snaps closed.  Won't know for a few years if it'g going to
hold up with the weather, but it never gets cold here in So. Calif. so
it's not much of a test.  That's what I would use if I were in your
place, because it's a whole lot easier than hassling with stuff inside.
It comes in some colors but should be easily painted.
Site Timeline
