LAN and Telecom Cabling seeking vga cable extension advice
Subject Author Date
seeking vga cable extension advice greg t. knopf 02-03-06
Posted by greg t. knopf on February 3, 2006, 9:36 am
Hello,
I have a customer with the following desire. In a room 15' across,
they are going to place a large flat screen TV on one wall. Opposite
that will be a couch along with a desktop PC. They will also use their
laptops from this couch.
The customer likes to use either the PC or their laptops to hook up a
VGA cable to the TV screen and use that as a monitor.
I would like to provide them with a wall jack with a female VGA
interface on both sides of the room. The jacks will be connected via a
crawlspace.
Does anyone know of a jack connector which I can mount in a wall box for
a VGA female interface? And how is the cable connected to the jack, by
soldering it?
I know that it would be possible to run a pre-made cable into the wall
and through the crawlspace but even that has it's challeges. For one, I
do not like having a loose cable sticking out of the wall. Also, the
house rests on what looks like had-hewn 10"x 10" beams intead of the
uusual 10" x 12" x 2" board. As it is I will probably have to knock out
some of the cinder block which makes up the foundation.
Anyway, I would appreciate any advice.
Thank you,
- Greg Knopf
info@knopfnet.com
Posted by Al Dykes on February 3, 2006, 9:55 am
>Hello,
>crawlspace.
>soldering it?
>Thank you,
>- Greg Knopf
> info@knopfnet.com
Without digging into it, myself, these folks probably have what you
need, and maybe ideas. Get the paper catalog. It's more interesting
than the web site.
http://www.smarthome.com/
These people have lots of parts you might find interesting.
http://www.milestek.com/
There's always Black Box. Expensive but quality stuff and (the last
time I called) very good technical advice from their "application
engineers".
http://www.blackbox.com/
As a general comment. Quality counts in long VGA wiring. When i did
it for high-res (1200x???) ceiling-mounted video projectors it was
obvious that the cheapo cables caused ghosting. A crappy drop cable
from the VGA wall plate to the user's laptop would cause noticeable
ghosting. The in-wall cable we used was specified by the A/V outfit
that sold us all our gear. I don't recall what it was.
Depending on the length of the run and the capacitance rating of the
cable you might have high frequency roll-off and video degradation.
a d y k e s @ p a n i x . c o m
Don't blame me. I voted for Gore.
Posted by Robert Redelmeier on February 3, 2006, 10:42 am
I'd go pre-made. Easier than figuring out what to do.
Strip the screws and tape up well after attaching the fish
string to the _cable_.
> into the wall and through the crawlspace but even that
> has it's challeges. For one, I do not like having a
Nor do I. Sandwich the end into a metal wallplate.
Then provide patch-cords to take the wear. You might
want to look at a powered video switchbox (or even one of
the cute Iomega KVMs) to do amplification, but it probably
isn't necessary for that short a run.
People do this all the time for conference-room projectors.
-- Robert
Posted by James Russo on February 3, 2006, 3:11 pm
> crawlspace.
I'd think you should be able to use a d-sub wall plate.. I think a
monitor cable would fit in a DB9.
google 'dsub wall plate' and see if some of those results help you out.
-jr
Posted by none on February 3, 2006, 8:40 pm
> > crawlspace.
Or you could just buy a wall plate and jack made for VGA connections (HD15),
plenty of places sell them.
----== Posted via Newsfeeds.Com - Unlimited-Unrestricted-Secure Usenet News==----
http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+
Newsgroups
----= East and West-Coast Server Farms - Total Privacy via Encryption =----
Similar ThreadsPosted
seeking vga cable extension advice February 3, 2006, 9:36 am
Need telephone cable installation troubleshooting advice October 31, 2005, 4:42 am
T1 demarc extension February 21, 2005, 11:17 am
Multiple T1 Extension February 1, 2006, 6:39 pm
Basic UTP tool advice November 29, 2004, 7:01 pm
Telephone wireing advice please. November 30, 2004, 5:01 am
Home Networking Advice May 9, 2007, 2:46 am
Looking for advice on Telephone / Network System within UK September 6, 2004, 7:03 pm
Need advice for a wall-mounted patch panel for home network January 17, 2006, 10:34 am
OTDR: Launch Cable; Receive Cable April 10, 2008, 2:46 pm
Can I use a CAT5 cable as a TV Coax cable? October 14, 2006, 2:13 pm
Which end is bad of cable July 7, 2005, 10:51 pm
Cable Managers - 1U vs 2U August 12, 2004, 11:01 pm
Re Cable Managers - 1U vs 2U August 13, 2004, 10:28 am
What is the best way to strip Cat 5 cable November 27, 2004, 12:17 pm
