________________________________________
Completely off the wall and forgive me if I haven't read all the messages well enough to see if these suggestions have been covered. But, if it were me:
-----1) I would abandon the idea of laying the cable on the ground. Even if it required using a jack knife to cut a 2" slit to push my cables into for the entire length, I'd do it.
-----2) Fiber is not as expensive as you might think. The most expensive part of fiber is the electronics and the terminations. Someone already linked to these transceivers
and you can get pre-terminated fiber here
(but I'm not suggesting this is your best source or option).
-----3) Now comes the issue of power. Here's where I speculate. D-Link (and others), sell POE adapters for about $40.00. I like the D-Link Adapters
because there is a switch on the Terminal unit, allowing you to choose 5vdc or 12vdc. This is more versatile. THEY ARE INTENDED FOR 328' MAXIMUM. So, you'll have to do some testing or make modifications here.
Here's how they work: The Base Unit plugs into 120VAC. It puts out
48VDC and runs that power out the cable pairs that aren't used for data. On the opposite end the cable plugs into a Terminal Unit and out of the terminal unit you choose 5vdc or 12vdc through a pigtail and get Ethernet as well. At 700 feet, I wouldn't rely on the Ethernet connection.
However, it may be a power solution. The question is, how much amperage is left at the end? If not enough, with careful calculations, you may be able to replace the Base unit with a power adapter of sufficient size to provide sufficient voltage by time you hit the Terminal Unit and USE THE POE KITS SOLELY AS A METHOD OF PROVIDING CORRECTLY LEVELED CURRENT.
4) In summary, I'd go this way: Run fiber (for the data) and your copper (for power) as separate issues. Obtain power at the head end for your first transceiver. Obtain power at the head end for your modem and router. Obtain power at the head end for TWO POE ADAPTER KITS Use one POE adapter kit to run power up to the second transceiver at the tower. Use the second POE adapter kit to run power up to the access point at the tower.
Of course, your transiever and access point will have to be properly rated for the output of the POE adapter(s) you choose.
Just a thought.
Dorral Goforth
