I'm ordering a bunch of short Cat 6 patch cables and found an inexpensive supplier. The supplier apparently uses cables made by Abergetty, whom I've never heard of. Abergetty's website is almost nonexistent, but the supplier says they meet or exceed the 568-B.2-1 standard and are UL certified. They say nothing of being fluke tested or certified, and I wondered if I could regret buying these patch cables. Do I need to worry? Is a Cat 6 patch cable a Cat 6 patch cable?
Thanks,
BJ
