OM3 patching on OM1 cable?
Hi
Can anyone tell me if there is practical adverse effects using OM3 fibre patch leads to connect equipment to OM1 cabling? At a very basic level I would think the receive leg would be degraded as you come from thick to thin. I do not have access to test gear to try it out at the moment.
TIA
Mick
mlyons
snipped-for-privacy@emergency.qld.gov.au skrev:
The ressult vil be high attenuation (arround 2-6 dB) in one direction and the link will normally not come up or even vorse be unstabile.
CablingGuy
