Hi
My friend is working on a project where he will be changing over a bunch of offices from a BT WAN to NTL.
the final part of the change over uses a patch cable to plug NTL's network termination equipement into the main office switch. (and then disconnecting BT).
where BT and NTL's NTE kit is in the same cabinet, a short factory made patch cable will be used to connect from switch to NTE.
This cable will carry ALL WAN traffic for the whole office - in one case more than 100 computers running applications hosted remotely at telehouse, london.
however, where the new and old kit are in different cabinets, maybe 10 metres away, he is considering making up cables using pretty much any reel of cat5e thats kicking around and rj45 connectors from maplins / b&q.
can anyone direct me to any web resource (white papers / horror stories etc )on the web that will help me convince him this is not a good idea.
Or do you think it will be ok?
Thanks
MJ
