You need a 110 punchdown tool. THey sell them in Home Depot or Lowes or Electrical supply houses.
If you are too cheap, you can use very small flat headed screwdriver to puch the conductors into the slot.
Or more accurately, how do I *apply* the wires (to this CAT6 terminal), since the colour coding is obvious:
Also, do I need a tool to do this? If so, what would it be?
Thanks for any help.
Jonathan
Thanks - and no stripping the insulation? Just punch down and that's it?
Yeap, that's it. It's an IDC (insulation displacement connection) contact. Does the job for you, no stripping needed. As a matter of fact I would advise to use the little plastic caps that were in the plastic bag with this jack to set wires down (may have to use pliers) instead of using a flat head screwdriver. The screwdriver can move the blades of the contact too far apart and render them useless or unreliable. Else get a specialized punch-down tool if you have to install number of these.
Thanks - not sure about the plastic caps you describe, but I think I might be able to borrow a punchdown tool from the IT guys at work.
