In my main telcom room, I have a cabinet with a patch panel that was pre-wired to a patch panel in my main data rack. I'm unclear about the proper EIA/TIA 606-A labeling standards as applied to this situation.
Do I consider the cabinet a different Telecommunications Space (TS) from the cabinet?
Do I label the patch panel in the cabinet identically to the panel in the main rack or just indicate in TS documentation that the two panels are pre-wired?
Should I treat this situation is as a work area outlet that happens to be in the same room and a full patch panel in size?
