Agreed. Lights mean signal and activity. Not _clear_ signal and good frames, at least for 10/100 on most equipment.
-- Robert
-- Robert
Yes. A professional punchdown shouldn't have that much untwisted wire.
No, never use shielded cable for ethernet.
For whenever 10GBase-T copper switches will be afordable (right now, its $1000 a port), plain Cat6 will support 10Gbps speeds at up to
55m. You need Cat6A cabling to reach 100m at 10Gbps. At that point, you need to have Cat6 patch panels, and Cat6 patch cables as well. Regular Cat5e patch panels and patch cables will fail. There's never going to be pulling them out and reterminating, any professional cable person will pull new cable for new panels.
I've gone into a few situations where exactly that did happen. Split pairs, and the interface only links up at 10Mbps. Fix the split pairs, and it works at 100Mbps with no gear (or config) change.
And there have been many posts over the years to this group with people coming here with that exact same problem.
I'm not saying that it happens all the time, but it does happen from time to time.
Why?
I already have cat6 patch panels and cat6a cables. Everything is set for future 10g-ethernet.
Nobody grounds the shield correct. The specs were all written for UTP. The balanced driven pairs of Ethernet are very good at avoiding noise. The shield (even properly done) often attracts more noise into the circuit than UTP does by itself.
STP is for applications that aren't balanced drivers. (ie. RS232 serial data).
At the prices you previously quoted? Those are some amazingly cheap Cat6 patch panels..
If it is only a question of grounding, I am not nervous. The place I work at hire a couple of electrical engineers ... I should be OK to find a grounder among them.
Beside, what you say surprises me. I see many articles about the pros of using STP for lan purposes.
A cat6 96 ports patch panels is around 125$.
Which way do you consider correct? Tie both end and live with the ground loops? Tie one end (which? head? or stn?) and ground the other through a resistor/cap (which)?
Originally, yes.
Maybe. I've seen radiation from 100 onto NTSC ch 2. If STP is so worthless, why is so much of it installed an Europe? Wouldn't the EMI test be easy to pass? And if STP is so worthless, why is it even available in N.Am where EMI tests are rare?
Certainly more necessary there. Not worthless for ethernet.
-- Robert
Only through a freak of nature. For the umpteenth time, the autonegotiation protocol is always done at 10Mbps, it does not have any kind of cable test (other than that the two ends have to be able to communicate in order to negotiate), and it does not have any kind of fallback other than, if the two ends can't communicate, the assumption is that the other end doesn't support autonegotiation/100Mbps so then the link falls back to 10Mbps. So, the only way to get a fallback to
10Mbps is if the link is so bad that autonegotiation fails, which means the link doesn't really work at 10Mbps, either. If the split pairs only affect one direction and the majority of the data transmission is in the other direction, then it's possible that you won't notice how bad the bad direction is unless you specifically look for it.-- Larry Jones
The hardest part for us avant-garde post-modern artists is deciding whether or not to embrace commercialism. -- Calvin
