I just bought a brand new house. All the wiring for the house telephone lines was done with CAT5e cable, and all the ports have RJ45. There is a large junction box in the garage that contains all the coax cable and cat5e cables.
The specific cable that's giving me headaches is one from the box in the garage to the living room. The cable needs to go up (no more than
25ft), then across 3 bedrooms (no more than 50ft) then back down to the living room (25ft).I have a Linksys WRT54G router connected in the garage box. I've tried plugging in various things, but nothing works reliably. I lave a win2k laptop whose ethernet card's "link" light will not stay on. If flashes every 2 seconds or so. (The router link light also does not stay on). I tried plugging in an xbox - but it can't get an IP. I tried plugging in a linux box, it's ethernet card's link light shows up - but it can't get an IP. I tried plugging a linksys switch (uplink port.) The light stayed on - but all attempts to ping the router (using static IP) or get an IP via DHCP didn't work. What's the MOST puzzling is that there are 2 cases where I DID get it to work. I have a winxp Thinkpad. It's built-in ethernet card linked up and got an IP successfully. Also, changing the win2k laptop to use 10baseT mode (instead of 100baseT) got its link light to stay on, and get an IP.
This is so strange. What I really want is either my linksys switch or linux box to work. (I want to use the linux box as a media center in the living room). I've never experienced such a strange networking problem. At first I thought it is a cable length issue - but I'm way below the maximum 90m allowed. That also doesn't explain why the winxp box was able to connect right away.
All the other ports in the house are working like I would expect - except the living room one.
Is there anything else I could try to boost the signal somehow? In theory, this should work right? Do you think this is a faulty wiring job? Could "crosstalk" or other network interference cause this? Do you think it would be worth it to call some local communication experts to help me out? I don't want to spend a lot of cash fixing this problem.
