I am looking to put a cat6 patch panel in a structure wiring enclosure. I need 24 ports so I was considering using 2 vertical 12-port mini patch panels (one on each side) attached by 89D brackets screwed into the sides of the enclosure. Will this work? Will I be able to run the Cat6 to the panels without exceeding the bend radious requirments?
Also, I am planning getting a structured wiring enclosure. I know some do not like the proprietary ones but it will be in a finished basement so I need something that can fit everythng (patch panels, phone and video distribution, ethernet switch) inside. I am thinking about getting a 42 inch OnQ or Greyfox enclsoure. Any other recommendations?
Also, please feel free to let me know if I am being a knuclehead with this plan. Thanks.
