LAN and Telecom Cabling cabling jammed together
Subject Author Date
cabling jammed together Power Cat 10-12-04
Posted by Power Cat on October 12, 2004, 10:50 pm
Greetings. I would appreciate input from the group. I acquired an
aged house recently and running network wire and cable is proving
challenging. I can create a run to most of the house but my new
network wire and coax cable will end up bundled en masse in close
proximity for about 50 feet before being distributed. Is this a
problem?
In other words, if I do multiple network/cable/phone runs to a number
of rooms and the lines must of necessity be bundled together (imagine
a six-inch diameter pile of wires), will there be interference between
these that will degrade performance?
Throw in a cable from an antenna in the mix too.
I've successfully networked and "cable-ized" houses and offices before
but I've never had to stack these so closely. I'm buying good quality
cable (quad shield) -- if this matters -- and nice cat 5e wire.
Thanks!
Posted by Robert Redelmeier on October 13, 2004, 6:03 am
> runs to a number of rooms and the lines must of necessity
> be bundled together (imagine a six-inch diameter pile of
> wires), will there be interference between these that will
Almost certainly no problem. Cat5e is frequently bundled
and run in 6" bundles. Cable should be likewise no problem --
it's well shielded and carrying the same signal.
-- Robert
Posted by Mark Evans on October 14, 2004, 12:53 pm
If you tie the bundle together you should not
overtighten the cable ties/lashing cord. Both
twisted pair and coax cable react badly to being
crushed.
Mark Evans
St. Peter's CofE Aided School
Phone: +44 1392 204764 X109
Fax: +44 1392 204763
Posted by Dmitri(Cabling-Design.com on October 13, 2004, 3:41 pm
> problem?
> offices before
> Thanks!
Bundling CAT5E cables has never been a problem. As a matter of fact, up
until very recently the industry did not care how much signal leaked out
of one cable and coupled into another. It's been recognized as a problem
with the emerging "augmented CAT6" standard, but the parameter they call
"alien crosstalk" has not made it into the standards as yet. Anyways, for
CAT6 cables manufacturers do not recommend bundling cables close together
in a neat fashion and rather have them "loosely" bundled. The worse it
looks, the better the electrical parameters ;-). They also do not
recommend to use nylon cable ties for bundling (use wider Velcro ties
instead), and also you are expected to place your ties at irregular
intervals.
Anyways, none of the above recommendations apply to CAT5E, so you should
be good bundling your cables just the way you got used to.
RG6 may be a problem, but is usually well-shielded, so you should not
experience any issues with that. As a matter of fact, you'll see the
problem on your TV, and not on your network. If a problem exists you'll
see random horizontal and skewed lines as well as "snow" when your PC
kicks in. Even then, if it happens, it is not always the cable's fault -
the devices themselves emit a lot, even before the signal hits the cable,
so it may be just interference from a PC nearby.
Dmitri Abaimov, RCDD
http://www.cabling-design.com
Cabling Forum, color codes, pinouts and other useful resources for
premises cabling users and pros
http://www.cabling-design.com/homecabling
Residential Cabling Guide
Article posted with Cabling-Design.com Newsgroup Archive
http://www.cabling-design.com/forums
no-spam read and post WWW interface to your favorite newsgroup -
comp.dcom.cabling - 4692 messages and counting!
Posted by Justin T. Clausen on October 13, 2004, 6:57 pm
powercat@verizon.net (Power Cat) wrote in message
> problem?
> Thanks!
There are a number of manufactures (Commscope most notably) who make a
"pre-bundled" cable that has 1-4 coax and 1-4 Cat5e in a single
bundle, and an occational fiber pair as well. I've never actually
used them, not usufull for my applications, but they're out there.
But as previously noted, no you should have any problems what so ever.
Similar ThreadsPosted
cabling jammed together October 12, 2004, 10:50 pm
Ethernet cabling used outside July 29, 2004, 7:57 pm
LSZH Cabling August 3, 2004, 10:11 pm
Help with telephone cabling September 26, 2004, 4:10 pm
Cabling length December 1, 2005, 4:47 am
Cabling Forums February 13, 2006, 9:58 am
cabling labels April 15, 2006, 4:50 pm
Need some pointers on my first cabling job March 25, 2008, 7:39 am
cabling for colorblind people? July 9, 2004, 11:10 pm
Data Communications Cabling FAQ October 29, 2004, 7:24 am
Data Communications Cabling FAQ July 29, 2004, 7:17 am
newbie cabling question August 24, 2004, 3:17 pm
Data Communications Cabling FAQ August 29, 2004, 7:28 am
Finally! Structured Cabling Gets Its Own June 25, 2005, 9:43 pm
Gigabit Ethernet Cabling November 17, 2004, 3:55 pm
