How does AMP's LightCrimp Plus ST connectors perform compared to other connector technologies (epoxy / oven UV systems)?
Would it be possible to use the LightCrimp Plus ST connectors to fterminate a 750m optical cable between two premises using off-the-shelf switches witjh optical ports?
Where can I find reviews and comparison charts for the different connector types? I have searched a bit but haven't found a site which objectively discusses and compares the LightCrimp system to others.
Does it exist other 'budget' and quick optical fibre termination technologies?
Thanks for comments, info and tips
regards
Tor
