LAN and Telecom Cabling What's the right way to terminate RG6 Quad with F-Conn compression connectors?
Subject Author Date
What's the right way to terminate RG6 Quad with F-Conn compression connectors? Frank B Denman 01-20-05
Posted by Frank B Denman on January 20, 2005, 12:26 am
I've been trying to fold back all four layers (two braid, two foil)
before pushing the cable into the F-Conn FS6U-RV connectors, and it's
might hard pushing.
I am suspecting that maybe not all of those layers want to be folded
back.
Does the innermost foil layer want to stay wrapped around the
dialectrec?
Do any of the outer layers want to get cut off rather than folded back?
Today I got my antenna and rotor back up on their roof mount and even
cleaned out the rain gutters. With a few clues on foil and braid
disposition, I'll be a happy camper indeed.
Cheers,
Frank
Frank Denman
Denman Systems
(please remove the x from my email address)
Posted by Jeff Liebermann on January 21, 2005, 1:16 am
On Wed, 19 Jan 2005 21:26:31 -0800, Frank B Denman
>might hard pushing.
Just the braid gets folded back. Not the foil.
This is for a different connector, but it's the same general idea:
http://www.interstateelectronics.com/howto/coaxterm.html
The FS6U is the F-Conn universal F connector. However, I couldn't
find anything with the -RV suffix. What's that?
Also, the tool should be doing the brute force work, not you. What
kinda tool are you using? If it's a bench vise and a hammer, forget
it.
>back.
Correct. Just the braid.
>dialectrec?
No, the connector plug slides between the insulated center conductor
and the foil. There's no way you can get the center conductor, plus
insulation, plus foil, into the center hole. Remove the foil.
Yes, all of them.
F-conn has a video on how it's done on their web pile:
http://www.icmcorp.net/demos/rg6u%20demo.wmv (8.4MB)
You can sorta see how the cable is prepared (except they covered up
the interesting part with text).
# Jeff Liebermann 150 Felker St #D Santa Cruz CA 95060
# 831.336.2558 voice http://www.LearnByDestroying.com
# jeffl@comix.santa-cruz.ca.us
# jeffl@cruzio.com AE6KS
Posted by Jeff Liebermann on January 21, 2005, 1:28 am
On Thu, 20 Jan 2005 22:16:53 GMT, Jeff Liebermann
Argh. That's wrong. The inner foil stays on the center conductor
insulation and it does fit in the connector hole. For quad shielded,
I remove the outer foil and outer braid. The inner foil stays put.
Only the inner braid gets folded back. I've managed to pound a
connector to together with both braids folded back, but it was rough.
(Reminder: Never yack with visitors while posting to usenet.)
Posted by Frank B Denman on January 20, 2005, 8:26 pm
Thanks, Jeff.
I had looked at both those pages, but had assumed they were showing some
kind of RG6 that had only a single layer of braid. The tool I'm using
is the CablePro LCCT-1, and with the information you have so kindly
supplied, the process is *way* easier.
Frank
Frank Denman
Denman Systems
Posted by Ed Nielsen on January 21, 2005, 1:13 am
Glad you realized that the bonded foil needs to stay there, bonded to
the dielectric. It needs to stay in place to maintain shielding integrity.
An excellent article on drops and cable preparation (w/pics) can be
found at <http://www.cencom94.com/links.html>. Click on the "Drops" link.
CIAO!
Ed
Similar ThreadsPosted
What's the right way to terminate RG6 Quad with F-Conn compression connectors? January 20, 2005, 12:26 am
Installing S-n-S connectors on quad shield August 30, 2007, 7:53 am
compression or crimp April 5, 2005, 8:50 pm
Siamese Compression Fittings August 24, 2005, 8:20 pm
BNC Compression Fittings w/ Siamese Cable August 24, 2005, 8:20 pm
terminate patch panel. February 2, 2006, 9:22 am
RG6 Quad clips August 18, 2007, 12:30 pm
How to weatherproof RG6 Quad connections January 18, 2005, 2:25 am
FS: AMP Lightcrimp Plus Termination Kit w/new SC connectors August 3, 2005, 3:22 pm
Fibre optic crimp / terminate tool kit.. June 9, 2005, 10:17 pm
RJ45 connectors with a larger "gate"? September 22, 2004, 10:22 pm
RJ45 connectors with a larger "gate"? September 23, 2004, 9:59 pm
Corrosion in RJ11 / RJ45 Connectors April 14, 2005, 5:51 am
How to crimp RCA connectors onto RG59 coax July 11, 2006, 4:12 pm
CAT6 Requires Shielded Connectors? August 19, 2006, 1:26 am
