Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Al Dykes on June 25, 2007, 1:49 pm
Please log in for more thread options Is there an analog to the 66 block with 110-type punchdowns? What is it called? Assuming there is, can one do cross-connects that are CAT5e or even CAT5-compliant? -- a d y k e s @ p a n i x . c o m Don't blame me. I voted for Gore. A Proud signature since 2001 | |||||||||||||
Posted by Doug McIntyre on June 25, 2007, 3:41 pm
Please log in for more thread options adykes@panix.com (Al Dykes) writes: A 110 block. >Assuming there is, can one do cross-connects that are CAT5e or even
>CAT5-compliant? Hubbell's 110 blocks are Cat5e compliant. http://www.hubbellcatalog.com/hubbellpremise/datasheet.asp?PN=110BLK100BWL&FAM=CrossConnectBlocks Many other manufacturers are as well. I haven't seen any cat6, but then again, most cat6 stuff is still pretty specialized. If you want to get the cat5e rating, make sure to not unwind your pairs too much, you still have to get them within half an inch of termination, even on your cross-connects. | |||||||||||||
Posted by 65.82.33.222 on June 26, 2007, 8:58 pm
siemon company part number is S110AB2-100FT. This is for the kit that includes the legs, labels and clips. It will do 100pr. -- 65.82.33.222 - Unregistered User ------------------------------------------------------------------------ View this thread: http://www.futurehardware.in/600505.htm http://www.futurehardware.in | |||||||||||||
Posted by Carl Navarro on June 26, 2007, 11:47 pm
On 25 Jun 2007 13:49:43 -0400, adykes@panix.com (Al Dykes) wrote: >
In Siemon part it's an S110DW1-50-89.
> >Is there an analog to the 66 block with 110-type punchdowns? What is >it called? > http://www.siemon.com/apps/Utilities/showImageDisplay.asp?showImage=/share/products05/110_vertically-mounted-s110-blocks_S110DW1-50-89_big.jpg >Assuming there is, can one do cross-connects that are CAT5e or even
>CAT5-compliant? Hmmm, if you can do it on a 110 block, yes. It isn't a whole lot of fun, because the jacket keeps the twists in place. Your jumper wire ends up being jacketed Cat-5e cable. Except for the density, I'd either use the Leviton plate with 12 holes on an 89 bracket, or the 6 jack 89 bracket http://www.siemon.com/apps/Utilities/showImageDisplay.asp?showImage=/share/products05/110_vertical-mount-panels_S110DB5-50JP89_big.jpg Carl Navarro | |||||||||||||
| Similar Threads | Posted |
| What is the part number for the 110 equiv of a 66 block? | June 25, 2007, 1:49 pm |
| We could supply Krone module,MDF block,wiring block,STB module,Etc | June 8, 2005, 9:55 am |
| Dishnetwork as part of a structured cabling network | March 30, 2005, 11:41 pm |
| 66 block - What did I do wrong? | February 9, 2006, 9:56 pm |
| Newbie: Punch down block 66 vs 110, how do these work? | March 18, 2008, 9:20 pm |
| MDF cross connection block test clips | July 21, 2005, 7:39 pm |
| We Could Provide Krone LSA PLUS Module(Disconnection Module)10 Pair Terminal Block,Kronection Box,Distribution Box | September 24, 2005, 12:50 am |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
>it called?
