LAN and Telecom Cabling Securing flexible conduit
Subject Author Date
Securing flexible conduit Ken Hornstein 07-21-04
Posted by Ken Hornstein on July 21, 2004, 8:02 pm
I've getting close to starting a major addition to our house. I'm
going to put some kind of conduit in the new sections of the house for
low-voltage wiring. I'm pretty sure I'm going to use the Carlon
flexible conduit (the stuff they call "Resi-Gard"), but I'm not
committed to it (if someone has a better suggestion, I'm open to it).
I'm planning on running 3/4" conduit from all of the boxes back to a
central location.
The contractor's electrian wasn't that interested in doing the conduit,
but the contractor didn't have a problem with me doing it. I used the
Carlon stuff in one room in the basement that I remodeled, and it worked
out fine ... except for one issue.
I hadn't fully appreciated how much of a pain it was to secure the conduit
to the framing members. I used the PVC "hoop" style clamps, and those worked
out okay ... but driving all of those screws took a lot of time, and in some
limited-clearance places I was forced to drill & countersink bolts & nuts to
secure the PVC clamps. I ended up using a fair number of these clamps,
because I didn't want the conduit to move around when I was pulling wire
through it.
I have to wonder if I was missing something. What are you supposed to use
to secure the PVC clamps to the framing members? Do people nail them? Do
you use drywall or deck screws? Traditional wood screws, with a pilot
hole? I guess with the rigid PVC, it's less of an issue because you don't
need as many clamps. But I had used that in _another_ room I remodeled,
and I discovered that I ended up spending a whole lot of time cutting and
fitting the conduit with all of the bends necessary (and that room didn't
even have that many bends). The flexible stuff was a _lot_ quicker in
this regard.
Is combining conduit types an option? I suppose it would make sense to
use the flexible stuff where you need lots of bends, but you could
use the rigit stuff for long, straight runs.
--Ken
Posted by vincee on July 21, 2004, 3:35 pm
> central location.
worked
some
to
> through it.
> this regard.
> --Ken
You can use 3/4" drive straps(a hook shaped nail in strap) to secure the ENT
(electrical non-metallic tubing). You can get them at a local electrical
supply house if your home store doesn't have them. The supply houses usually
stick it to the walk-in cash buyers though. Your contractor's electrician
probably has some or can get them.
I'm not sure why you need conduit unless its for future additions but if
your not opposed to the occasional attic crawl you really only need the pipe
to get you from the top (or bottom) of the wall to your boxes (or rings).
Just run it far enough out so it can be easilly reached in any tight areas.
Depending on how many bends you have it might be easier than trying to get a
fish tape through all of that pipe.
Vince
Posted by Ken Hornstein on July 23, 2004, 7:39 am
Thanks for the tip, I'll check them out.
Attic isn't an option, unfortunately (cathedral ceilings).
It turns out fishing a pull string through is actually dead simple. Tie
string to small plastic grocery bag, attach shop-vac to one end of conduit,
turn on shop-vac, and place bag in other end of conduit. Zips it
right through! With that, you don't have a problem pulling anything.
The one trick with doing _that_, however, is that you should pull a
double-length string (I suck the string through, leave a couple of
extra feet, mark the end of the string still connnected to the spool
with a black marker, and then pull more string until I see the black
mark at the other end). That way, when you pull a cable, you can
pull from the middle and you've still got the string when you're done.
--Ken
Posted by Michael Quinlan on July 23, 2004, 7:16 pm
Anyone know how well this technique works with cable in the conduit already?
When I put in pull strings, I make it double length also. But when I'm
done pulling another cable, I pull the string back so I can use it
again. This technique has a limited life span though, as the pull
string gets increasingly tangled with the cables after each pull.
Posted by Chuck Yerkes on July 22, 2004, 6:57 am
Kerberos Ken H?
> central location.
3/4" is pretty big. But sure.
Woo hoo! Can't lose with that.
> I used the
Any reason not to use PVC pipe? Use the flexi-pipe on those odd corners
and what nots.
PVC doesn't need quite as much support as stuff that droops.
(and reading ahead, UL is moot with low voltage).
Theory only, but pneumatic nails guns are easy to use and quick.
> Do
> hole?
It's never gonna move or be redone. drywall screw weakness is shear.
You don't reall yhave a shear issue in a wall.
I appreciate your want to use conduit - it's future proof and you have
the ideal opportunity.
Similar ThreadsPosted
Securing flexible conduit July 21, 2004, 8:02 pm
Pulling fiber in flexible conduit February 11, 2005, 7:52 pm
Overfilled conduit! March 28, 2007, 2:21 am
Re: ethernet and AC in same conduit January 2, 2009, 8:47 pm
Pullling cable in conduit August 8, 2006, 12:52 am
Re: Ethernet and AC in conduit for remote WAP January 3, 2009, 1:21 pm
ballasts & long conduit runs April 14, 2007, 11:35 pm
Pulling A Draw String through a long conduit? May 1, 2005, 5:12 pm
Existing conduit w/fiber,copper,pull string February 21, 2005, 10:56 pm
