LAN and Telecom Cabling Re: ethernet and AC in same conduit
Subject Author Date
Re: ethernet and AC in same conduit ps56k 01-02-09
Posted by ps56k on January 2, 2009, 8:47 pm
added the cabling & ethernet groups -
seaweedsl wrote:
> I know it's not recommended or allowed by the NEC , but I'm wondering
> if anybody knows how likely I am to have problems if I run ethernet
> and AC (120 volt) in the same conduit for 20 meters....
> thanks,
> Steve
Posted by David Lesher on January 2, 2009, 9:30 pm
None at all if you run the Ethernet over fiber.
If not, don't whine if your fire insurance is void...
A host is a host from coast to coast.................wb8foz@nrk.com
& no one will talk to a host that's close........[v].(301) 56-LINUX
Unless the host (that isn't close).........................pob 1433
is busy, hung or dead....................................20915-1433
Posted by ps56k on January 2, 2009, 9:39 pm
hmmm - we ran the AC in the required conduit and metal boxes
to totally contain the AC/fire gremlins.
The "low voltage" stuff in the drop/plenum ceiling was a little trickier...
Either - it was the more expensive "plenum" cable, hung from the I-beams,
or run inside a pipe/conduit just for physical protection
and it would exit from the conduit at a patch panel on either end.
Same with the low voltage telco/phone wiring.... which you didn't mention.
Posted by Robert Redelmeier on January 2, 2009, 11:43 pm
>> wondering if anybody knows how likely I am to have problems if I
>> run ethernet and AC (120 volt) in the same conduit for 20 meters....
What would a "problem" be for you?
In theory, ethernet and 60 Hz AC won't interfere with each
other, so separation and isolation are irrelevant. Now, if
that AC is going to some noisy electrics (arc welders) or to
some sensitive equipment, there might be some interference.
But you are taking an unapproved risk and depriving others
of a layer of protection. Break the insulation, either by
a pulling scar or mechanical accident, and they are _much_
closer to a fatality. Do you want other people setting
traps for you? Don't set them for them!
-- Robert
Posted by glen herrmannsfeldt on January 3, 2009, 3:15 am
As far as I know, it will likely work fine.
As you say, not allowed by the NEC. Some time ago, I predicted
that you could run ethernet with 240VAC common mode on the cable,
but I never got around to trying it. (Also not allowed by the NEC.)
Use cable ties onto the outside of the conduit.
-- glen
Similar ThreadsPosted
Re: ethernet and AC in same conduit January 2, 2009, 8:47 pm
Re: Ethernet and AC in conduit for remote WAP January 3, 2009, 1:21 pm
Overfilled conduit! March 28, 2007, 2:21 am
Securing flexible conduit July 21, 2004, 8:02 pm
Pullling cable in conduit August 8, 2006, 12:52 am
Pulling fiber in flexible conduit February 11, 2005, 7:52 pm
ballasts & long conduit runs April 14, 2007, 11:35 pm
Pulling A Draw String through a long conduit? May 1, 2005, 5:12 pm
Existing conduit w/fiber,copper,pull string February 21, 2005, 10:56 pm
Re: Conduit Size & Cable Fill Capacity - 2004 post - what about RG6? April 3, 2005, 3:05 pm
DIY Ethernet September 10, 2004, 8:57 pm
Ethernet cabling used outside July 29, 2004, 7:57 pm
Cat 5 for phone and ethernet? December 20, 2004, 9:57 pm
Cat 5 for phone and ethernet? December 20, 2004, 9:56 pm
PoE and Ethernet switches October 1, 2005, 10:22 am
Residential Cabling Guide
Home Cabling Guide
Finally, an instantly downloadable book that saves you thousands in home improvement dollars! Enjoy living in 21st century technology-advanced home while increasing its selling value and competitive advantage on the real estate market. Whether your cabling is for home office or high-tech leisure, you can wire your home yourself or learn "wirish" to speak with your cabling contractors in their language!
Learn More
