Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by scolio on April 18, 2007, 10:59 pm
Please log in for more thread options szilagyic@gmail.com wrote: >
I would stay away from the compression type connectors. The captive plastic
piece tends to wear or break and the ferrel becomes loose. Crimp style is tried and true for the best results Canare makes a good product but most of their stuff requires their strippers for optimum results. I personally would recommend ADC or Kings connectors, Belden cable, and Exelite strippers. | |||||||||||||||||||
Posted by Carl Navarro on April 18, 2007, 11:41 pm
and true for the best results Canare makes a good product but most of their stuff requires their strippers for optimum results. I personally would recommend ADC or Kings connectors, Belden cable, and Exelite strippers. LOL When even Ideal sells a compression tool and connectors I don't think there's an issue. The 70 motel rooms and bar I did 4 years ago with compression fittings has had one failure and that's even after the PPV drones came in and messed with the feeds. Maybe Time Worthless is next to go back to crimps next month..... | |||||||||||||||||||
Posted by Ed Nielsen on April 19, 2007, 9:19 am
Never seen that happen. If you're qorried about the plastic piece, then use ones that have no plastic, such as SuperLok or PCT <http://www.cencom94.com/gpage1.html>.
> plastic piece tends to wear or break and the ferrel becomes loose. Crimp > style is tried and true for the best results Canare makes a good product > but most of their stuff requires their strippers for optimum results. I > personally would recommend ADC or Kings connectors, Belden cable, and > Exelite strippers. | |||||||||||||||||||
| Similar Threads | Posted |
| Re: RG-6 QS, top brands? | April 18, 2007, 10:59 pm |
| Insertion rating of various brands of CAT6 jacks? | March 4, 2007, 12:47 pm |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
