LAN and Telecom Cabling Re: Proper way to install shielded (STP) Ethernet
Subject Author Date
Re: Proper way to install shielded (STP) Ethernet Phil Schuman 08-11-06
Posted by Phil Schuman on August 11, 2006, 5:25 pm
just thought I'd x-post this interesting thread to the cabling newsgroup
> BJ wrote:
> > We're having our office rewired; old Cat3 and Cat5 wiring is being
replaced
> > with a shielded Cat6. (The reason for shielded is another subject
> > completely and is a done deal, so please, no "Why Shielded? You
don't need
> > it" posts. I will say that having a shielded solution is of lesser
> > importance today, but will take on greater importance in the
future.)
> (big snip)
> I first learned about the problems of grounding looking at a big
> rack full of electronic equipment, all with the ground connection on
> the power cords cut off...
> > - If I'm only concerned about EMI in my horizontal cabling
locations, and
> > think EMI will not be an issue in my rack or office locations at
present, is
> > it appropriate to use unshielded patch cables, as long as the
shielded
> > horizontal cabling is properly grounded to the patch panel (which is
itself
> > grounded thru a properly-grounded rack)?
> Are you asking about EMI from ethernet to other equipment, or EMI from
> outside into ethernet?
> Shielding and grounding is a complicated subject once you have more
> than one piece of equipment that is line powered. Electrically,
> the best way is to have only one point connected to earth ground,
> with everything else grounded through the shield. This often doesn't
> agree with electrical codes requiring equipment to be grounded through
> the power line.
> > - If the cable shield is ungrounded, does the shield simply provide
no
> > benefit, or does it create the potential to cause harm? I've read
> > speculation that an ungrounded shield could act as an antenna that
actually
> > increases EMI exposure to the pairs inside.
> Ethernet is transformer coupled, and is pretty immune to outside EMI.
> The possible exceptions are factories full of arc welders, or inside
> a building with a high powered radio transmitter. There are possible
> resonant situations where the shield length might be the appropriate
> multiple of a half wavelength for a nearby EMI source, or for the
> ethernet signal itself. In some cases a resistor between the shield
> and the rest of the system might be needed.
> > Please understand, I'm not asking for an opinion about whether EMI
is likely
> > to pose a problem in my environment; I'm asking for sound ethernet
grounding
> > theory.
> Without knowing the possible EMI sources, it is hard to say. Sound
> grounding theory says ground the cable to earth at only one point,
> everything else grounds through the cable shield. There can only
> be one grounding path between any two pieces of equipment, and that
> path is through the shield. RJ45 connectors are not very good at
> making ground contact, so you should connect from the shield to
> a screw connection on each end of the cable.
> -- glen
Similar ThreadsPosted
Re: Proper way to install shielded (STP) Ethernet August 11, 2006, 5:25 pm
Re: Proper way to install shielded ethernet August 13, 2006, 12:07 pm
Shielded Cat5e for Gigabit Ethernet September 14, 2004, 9:35 pm
CAT6 Requires Shielded Connectors? August 19, 2006, 1:26 am
Proper, clean cable management (howto) May 18, 2007, 11:47 am
Cat 5 Install Pricing June 30, 2008, 9:16 pm
Concerns over Cat6 install November 19, 2007, 5:21 am
Question on getting proper spec cable installed from the pole to the house August 8, 2006, 1:04 pm
First office install, looking for suggestions and suppliers July 25, 2005, 11:39 pm
Sell Cat5e Modular Patch Panels,AMP Network Modular Patch Panels,Panduit Patch Panels,Mini-Com Shielded Modular Patch Panels March 15, 2006, 8:28 am
DIY Ethernet September 10, 2004, 8:57 pm
Ethernet cabling used outside July 29, 2004, 7:57 pm
Cat 5 for phone and ethernet? December 20, 2004, 9:57 pm
Cat 5 for phone and ethernet? December 20, 2004, 9:56 pm
PoE and Ethernet switches October 1, 2005, 10:22 am
