LAN and Telecom Cabling Re: Ethernet connection sensitive to cable length
Subject Author Date
Re: Ethernet connection sensitive to cable length ps56k 05-03-08
Posted by windsurferLA on May 4, 2008, 12:25 am
reply at bottom
Robert Redelmeier wrote:
>> windsurferLA wrote:
>>> Location #2 ? WORKS fine when linked by home built 40? long
>>> CAT5 cable. Location #3 ? DOES NOT WORK when linked by home
>>> built 100? long CAT5 cable. ? Not only is there no communication
>>> over the link, but the lights on both routers do not even
>>> indicate a connection. YET, if at this same location #3, the
>>> 100? long cable is plugged into any one of several computers,
>>> the connection indicator lights come on immediately, and full
>>> normal network access is quickly obtained.
> These homebuilt cables, which wiring pattern did you use?
> T-568A or -B ? If you don't know what I'm talking about,
> it is highly likely you split a pair.
> Please do not complain "but the other comp works".
> Difference NICs and drivers are more error-tolerant
> and have more robust fall-backs.
> Electrons may be color blind, but they _do_ know
> who their dance [twist] partners are.
> -- Robert
Robert ... thanks for the hint.. the likely cause has been identified.
When you asked about T-568A or T-568B, it triggered a memory. I then
recalled that the connectors were not assembled at the same time; one
end was rebuilt because of intermittent connection problems. The
intermittent end had been the very first RJ45 connector that I had ever
assembled. I further recalled being uncertain at the time I was
rebuilding the connector whether to use the "A" or "B" configuration.
Now doubting my wiring skills, I got out my jeweler's eye loop to very
carefully look at both ends to make sure one had not be wired "A" and
the other "B." The result was not what I expected. A careful
examination of the newer end appears to reveal that the blue-white (#5)
and the green white (#3) were inadvertently interchanged at that end and
only that end.
I expect that repairing the cable will solve the problem. WHAT I FIND
SURPRISING is that the cable has worked with so many (guest's) computers
for so long that it was not until the A - B question was raised that I
thought to check the colors of the inner wires - a not so easy a task
for old eyes like mine. Obviously, there is enough cross talk between
the pairs to effect a connection with most, but not all, hardware.
Although I feel rather stupid for not spotting the wiring error earlier,
I never suspected a wiring error would be the problem. When ever I
assemble a connector, I keep a multi-colored wiring chart right in front
of me. Obviously, it was not enough to preclude the error.
Thanks for everyone's help.. Tomorrow, we try a rebuild.
Posted by Robert Redelmeier on May 4, 2008, 3:22 pm
That's the idea.
> loop to very carefully look at both ends to make sure one had
> not be wired "A" and the other "B." The result was not what
> I expected. A careful examination of the newer end appears to
> reveal that the blue-white (#5) and the green white (#3) were
> inadvertently interchanged at that end and only that end.
This is the most common newbie wiring mistake. Swapping
the whites turns the layout into side-by-side and splits
the green and blue pairs.
> I FIND SURPRISING is that the cable has worked with so many
> (guest's) computers for so long that it was not until the A -
> B question was raised that I thought to check the colors of the
> inner wires - a not so easy a task for old eyes like mine.
It is hard for everybody, and impossible with some cable
mrfs where the whites are unmarked (some plenum).
> Obviously, there is enough cross talk between the pairs to
Crosstalk is not really required. rememeber the signal is
differential and also present full-strength on the green.
Still, a bit surprising it ran as well as it did. Of course,
it never needed to carry more than 1 MBps, so retransmits
would go largely unnoticed.
> error earlier, I never suspected a wiring error would be
> the problem.
Many years of experience have led to to _ALWAYS_ check the
cabling first. Especially if there is any indication it is
home-made. It is incredibly difficult to crimp connectors
correctly.
-- Robert
Posted by DLR on May 6, 2008, 2:30 pm
> That's the idea.
Which is why I like the Leviton Quick port for the part time do it yourself
crowd. You can buy the jacks at Home Depot on Saturday afternoon and they have
the wire colors on the sides of the jacks.
David
Posted by Robert Redelmeier on May 6, 2008, 3:53 pm
> time do it yourself crowd. You can buy the jacks at Home
> Depot on Saturday afternoon and they have the wire colors
Agreed. The key is _JACKS_ . They're much easier
to get right than _PLUGS_ .
-- Robert
Posted by DLR on May 6, 2008, 9:53 pm
I made a patch cord once. Then decided I had the cash to buy them. With hooded
and/or snag proof ends no less. At a price that valued my labor at $1 or $2 an
hour.
Similar ThreadsPosted
Re: Ethernet connection sensitive to cable length May 3, 2008, 12:37 pm
telephone connection with cat5e July 13, 2005, 10:40 am
Trouble with B2B fiber connection August 3, 2005, 9:03 am
Network connection only stable @ 10mbit. January 28, 2005, 2:09 pm
MDF cross connection block test clips July 21, 2005, 7:39 pm
Cable length July 18, 2006, 9:43 pm
Minimum 10Base100 Cable Length July 16, 2004, 9:32 am
Program to Estimate Cat 5 Cable Length October 1, 2004, 4:52 pm
Power + DSL signal in same 700ft cable length October 12, 2006, 6:35 pm
OTDR: Launch Cable Length for Singlemode April 10, 2008, 2:50 pm
Ethernet cable shield November 23, 2004, 5:02 pm
Ethernet Cable Woes - On and Off every second February 19, 2007, 8:20 pm
Firewire using on existing Ethernet cable August 6, 2005, 7:36 am
Cable over ethernet for two Wireless access points July 23, 2004, 6:57 pm
CAT-5 cable stuck in ethernet port - can't remove April 26, 2006, 5:49 am
