LAN and Telecom Cabling Re: Ethernet connection sensitive to cable length
Subject Author Date
Re: Ethernet connection sensitive to cable length ps56k 05-03-08
Posted by glen herrmannsfeldt on May 4, 2008, 4:09 pm
Rich Seifert wrote:
(snip)
> Believe it or not, between the last two sentences I just went outside my
> office and shot a bobcat who was chasing my house cat, whose name
> happens to be "Cat 3"(he is my third cat). No, I am not planning to
> upgrade him to Cat 5.
Shouldn't that be gato tres?
What do they call the wiring in Spain and Mexico?
(snip)
> (408) 395-5700 Los Gatos, CA 95033
-- glen
Posted by DTC on May 4, 2008, 6:39 pm
TIA/EIA 583-Ã
Posted by msg on May 4, 2008, 2:18 am
Jeff Liebermann wrote:
<snip>
4. In the miscellaneous category...ethernet over 25 pair
> telco bundles
...or perhaps LatticeNet?
Posted by Rich Seifert on May 4, 2008, 12:38 pm
> I once calculated the maximum cable length at about 1,200ft for
> 10baseT-HDX before timing becomes an issue. Why 2,000ft worked is
> still a mystery to me. It shouldn't have unless the timing on the
> ethernet devices is more relaxed than required.
The propagation velocity of UTP is about 5.1 ns/meter, or roughly
1.5 ns/foot. Your 2,000 foot run has a round-trip delay of around 6 us,
which is far less than the 48 us allowance in half-duplex 10 Mb/s
Ethernet (i.e., 51.2 us less the 3.2 us "jam" time). As long as the
*signal characteristics* were still acceptable to the line receiver, it
should work, as there are no protocol timing violations in this
arrangement.
Much of the timing allowance in ordinary networks is allocated to the
repeaters; I suspect that your setup was a two-station back-to-back
connection, which has LOTS of timing margin.
> Also, note that I was
> using 10baseT-HDX (half-duplex). Full duplex and/or 100baseT will not
> work due to collision domain issues and cable near end crosstalk.
Backwards. The collision domain (timing) issues are related only to
*half* duplex Ethernet, not full duplex. You can (and we often do) run
full-duplex Ethernet over tens or hundreds of kilometers (using fiber)
with no timing concerns.
Rich Seifert Networks and Communications Consulting
21885 Bear Creek Way
(408) 228-0803 FAX
Send replies to: usenet at richseifert dot com
Posted by Robert Redelmeier on May 4, 2008, 8:10 pm
> I enjoy asking the original questions backwards. In this
> case, it's "what would I have to do, to CREATE the problem"?
A good diagnostic method.
> At the time (about 1998), if you purchased any manner of pre-wired
> ethernet jumpers, you got EIA-568B wiring. Never mind that EIA-568A
> is the real standard. Well, my accomplice was working on his BICSI
> certification, and they were preaching EIA-568A.
Probably because the US government requires -A
> Never mind that I told him that I wanted the color coding to
> be consistent throughout the entire building, all of which
> was EIA-568B.
While US industry historically has been -B
> Careful here. That's not an endorsement for installing 2,000ft
> CAT5e runs. I once calculated the maximum cable length at
> about 1,200ft for 10baseT-HDX before timing becomes an issue.
> Why 2,000ft worked is still a mystery to me. It shouldn't have
> unless the timing on the ethernet devices is more relaxed than
> required.
10basedT has such relaxed timing because of the cascading
permitted. It became 100baseTX by tightening the circle.
Timing is mostly relevant for collision situations. If you
are isolated by a switch, how can it matter?
> Also, note that I was using 10baseT-HDX (half-duplex).
> Full duplex and/or 100baseT will not work due to collision
Keeping crosstalk out is probably the main benefit.
> As for stretching the technology, I done my part:
I hope these installations have adequate lightening
protection!
> One of these days, I'll follow the standards and rules,
> but not this week.
That's fine when expertise is available for troubleshooting
and the reliability is acceptable.
-- Robert
Similar ThreadsPosted
Re: Ethernet connection sensitive to cable length May 3, 2008, 12:37 pm
telephone connection with cat5e July 13, 2005, 10:40 am
Trouble with B2B fiber connection August 3, 2005, 9:03 am
Network connection only stable @ 10mbit. January 28, 2005, 2:09 pm
MDF cross connection block test clips July 21, 2005, 7:39 pm
Cable length July 18, 2006, 9:43 pm
Minimum 10Base100 Cable Length July 16, 2004, 9:32 am
Program to Estimate Cat 5 Cable Length October 1, 2004, 4:52 pm
Power + DSL signal in same 700ft cable length October 12, 2006, 6:35 pm
OTDR: Launch Cable Length for Singlemode April 10, 2008, 2:50 pm
Ethernet cable shield November 23, 2004, 5:02 pm
Ethernet Cable Woes - On and Off every second February 19, 2007, 8:20 pm
Firewire using on existing Ethernet cable August 6, 2005, 7:36 am
Cable over ethernet for two Wireless access points July 23, 2004, 6:57 pm
CAT-5 cable stuck in ethernet port - can't remove April 26, 2006, 5:49 am
